Specifies that a higher priority backup router preempts a lower priority master.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID for a VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| seconds |
Specifies a preempt delay period in seconds. The value range is 1 to 3600 seconds, or 0, which selects the original preempt delay period. |
Preempt enabled.
Delay configuration: 0.
The preempt option enables a higher-priority backup router to preempt a master with a lower priority. When a VRRP enabled router receives a lower priority VRRP advertisement and preemption is enabled, the higher-priority VRRP enabled router takes over as master. The new master starts sending VRRP advertisements and the old, lower-priority master relinquishes mastership.
The router that owns the virtual IP address always preempts, independent of the setting of this parameter.
If the preempt delay timer is configured for between 1 and 3600 seconds and the lower-priority master is still operating, the router preempts the master when the timer expires.
If the preempt delay timer is configured for 0, the router preempts the master after 3 times the hello interval.
The following command allows preemption:
configure vrrp vlan vlan-1 vrid 1 preempt
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
